coolant seeping from water pump bolt
Old Apr 19, 2008 | 08:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
got a little coolant seeping out from around one of the bolts holding the water pump on. I assume some RTV on the bolt will solve this issue? or do i need to pull the pump and replace the gaskets?
Old Apr 19, 2008 | 08:26 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: coolant seeping from water pump bolt
pull pump, replace gaskets thats your best bet
Old Apr 19, 2008 | 08:34 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You have nothing to lose by trying a thread sealant first. My bet is that'll do the trick.
JamesC
Old Apr 19, 2008 | 08:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i hope so. the gaskets are almost new.
Old Apr 19, 2008 | 09:50 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
at least 1 of the wp bolts goes into the water passage. A little thread sealant should work fine.
Old Apr 19, 2008 | 11:27 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Yeah I agree some thread sealant should do the trick,it's worked for me in past.
Old May 4, 2008 | 09:58 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Yep if the coolant is seeping out around the bolt head, just pull it and put RTV on it. That being said water pump gaskets are 60 cents each so i would pull the pump and put some black RTV on the threads of all the bolts and reinstall the pump.
Old May 5, 2008 | 09:26 PM
tomanahawk's Avatar
Car: 1992 Chev. Camaro (project car)
Engine: 5.0L V8
This same problem happened to me. I tried putting RTV on the bolts, but that didnt solve my problem. Pull the water pump, clean the surface on the block really really good, if there is junk on the surface it will leak out. Best bet clean it with a buffer (if you can) or with a gasket scrapper. What i did was put gasket maker on it made by Permatex instead of the gasket, some people dont like to do this.
If you decide to do what I did, put the gasket maker on the water pump first, then get two bolts and put rtv on them (you dont have to cover all the threads just about half way) thread the two top bolts dont make contact then thread the two bottem bolts. After that tourqe all the bolts. Wait for it to dry it says an hour, but there is a gasket maker that dries faster then that.
Oh the reason I used the gasket maker is because it filled out those gaps.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
