Did the shop put in the wrong radiator?
Old Apr 22, 2008 | 11:08 PM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Hi folks. I blew a radiator a few weeks ago- I mean BLEW IT UP! The thing split in two- damn plastic crap. Anyway, I had a shop put in a new one and the other day I am checking under the hood and my 5 year old goes 'daddy, it's leaking'. Bright lad. What he was pointing at was an additional outlet just below the radiator cap on the rear of the radiator that had a plastic/rubber cap hoseclamped on it. The cap was swollen, cracked and leaking. I replaced it with one I picked up on an emergency Pep Boys run, but tonight I had to replace THAT, because it was doing the same thing. Does this sound like a normal situation, or do you think they just used a generic radiator instead of putting in the correct one?
Old Apr 22, 2008 | 11:38 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: Did the shop put in the wrong radiator?
isnt that outlet supposed to go to the overfil tank?
Old Apr 23, 2008 | 12:28 AM
micktroup's Avatar
Engine: 5.7L V8
Transmission: auto
No, I have one of those! This outlet is bigger and below it...
Old Apr 23, 2008 | 08:48 AM
xbcrguy182x's Avatar
Sounds like an outlet to screw in a coolant level sensor. Go back to the shop and ask them to screw in a cork or something so it wont leak.
Old Apr 23, 2008 | 03:09 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
If it is large enough to take a 5/8ths heater hose then thats suppose to run to the heater core and climate control system plumbing distribution block thing.
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
TheExaminer
Aug 26, 2015 04:59 PM
dhonda200
Aug 11, 2015 11:50 PM
Leggman1
Aug 6, 2015 04:15 AM
