Amp Cooling
Old May 21, 2008 | 09:52 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Amp Cooling
I have a 1800 and a 1200 amp and the 1200 runs the subs and the 1800 runs the interior. The problem I am having is that the 1800 amp is getting to hot and none of the speakers are blown and im not putting to much load on the amp. Well it was getting so hot the sound was cutting out so I removed the end caps and pulled the rear deck cover to let more air back there. My amps are out in the open and they have never overheated like this before but I am going to run a cooling fan through the heatsinks. But anything else that could be suggested to keep the heat sinks cooler?
Old May 22, 2008 | 11:03 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: Amp Cooling
what i did was i made a shroud out of sheet metal, cut a hole in the middle, mounted a 12v computer cooling fan from radio shack on it, and wired it to the amp's "remote" terminal which turns the amp on and off with the deck. the result- a cooling fan that turns on and off with the amp. it hasn't overheated since- even in 95* summer weather.
i'll try to get some pics up in a little while...i'll post a link.
Old May 22, 2008 | 11:44 AM
Re: Amp Cooling
http://punkdude908.myphotoalbum.com/...umName=album04
the brace on the top is the only point where it's bolted down- otherwise it just sits over the amp. the fan was $10 or $15 from radio shack and the sheet metal cost maybe $10 from home depot.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
raymondandretti
Sep 27, 2015 06:43 PM
