Question about fan shroud..
Old Jun 1, 2008 | 12:34 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Ok so heres the deal I have a perma-cool 16 inch fan on my radiator right now...She is still overheating with the ac on...my question is will the listed fan shroud below fit the listed direct fit stock radiator?
http://store.summitracing.com/partde...5&autoview=sku
http://store.summitracing.com/partde...4294840138+510
Old Jun 1, 2008 | 04:55 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: Question about fan shroud..
no it's too tall. Needs to be like 2" shorter.
Old Jun 1, 2008 | 07:23 PM
Axle/Gears: Stock
Is there anyway to modify it to make it fit?
Old Jun 2, 2008 | 07:04 PM
stroker_SS's Avatar
Engine: 355
not unless your proficient at welding aluminum or have access to a shop with sheet metal sheers, sheet metal brake(bender), and riveting tools or tig welder.
But then of course you could just fab yourself up one like i did.
I wish i could fab one for you, but i don't really have access to that stuff anymore. try finding a shop such as a welding shop and see if they can help you out, you need to measure your rad. core height,width and how deep you want the shroud to be(i suggest 1.5 to 2").
Old Jun 3, 2008 | 01:09 AM
Axle/Gears: Stock
I ended up just pulling the permacool fan altogether and throwing a single electric fan that came off of a ford tauros with a shroud already attached. Took some modifying of the two radiator brackets but i got the thing to fit and man this thing is awesome! About an hour after running it I fried the relay for the fan and some of the wiring. It was rewired and repaired with a new higher amp relay and soo far so good this thing is running super cool. So far so good. Overheating issue diagnosed and resolved. For now.
Old Sep 26, 2009 | 06:02 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Nice job! I love seeing people come up with good solutions to simple issues. I'm also having a overheating issue. Do you happen to know what year Taurus it was? SHO by chance?
Old Sep 26, 2009 | 07:17 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
probably was from a 1991-95 3,8L taurus,'89 up SHO is
the same or nearly the same,this is a pretty good fan-
two speed motor,so must be connected properly or the
motor will burn out
Old Sep 26, 2009 | 07:36 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Thanks man. I will have to look into them.
Old Sep 27, 2009 | 08:30 AM
one92rs's Avatar
Car: SOLD!!!!!
there are several companies that make controllers for the two speed fans. look up lightning trucks or mustangs for there controllers. or you can run two of the single relays set ups to control both speeds.
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
