running hot need help
Old Jun 4, 2008 | 06:19 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
well my car is getting really hot like 210-230 all the time. i have a be cool rad. with two fans ,160 stat , air dam, trans cooler with own fan. and have checked levels
Old Jun 4, 2008 | 07:02 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: running hot need help
what did it use to run at? 210 is a good temperature even though alot of people will argue till there blue in the face otherwise....
Old Jun 4, 2008 | 07:16 PM
intex1982's Avatar
in old car 190 with stock rad. and fan.
Old Jun 4, 2008 | 07:18 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
is the bottom hose collapsing at higher rpm?
Old Jun 4, 2008 | 07:24 PM
intex1982's Avatar
hmm it dont get up that in rpm
Old Jun 4, 2008 | 07:34 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
crank ur car up and go look at the bottom hose and pull the throttle some i can see mine trying to colapse a lil at about 2k rpms....they make the hoses with the coil in them so this doesnt happen seems to be a problem for us...
Old Jun 6, 2008 | 10:20 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
did u have 10 to 1 compression on your old car.
ive got 10.8 to 1, i just started going around the block on mine and it seemed to go above 200 pretty quickly. i think im gonna get a bigger fan, i have enough room so why not. i changed the thermostat to 160 (from 180) and it seems to stay in the middle for a longer while. but i dont know, thinking of maybe playing w/ tha timming abit
theshackle
Mar 5, 2017 06:37 PM
BADNBLK
Nov 16, 2016 09:12 AM
ezobens
Aug 19, 2015 10:29 PM
jackhammer
Aug 15, 2015 10:04 PM
