HELP!! Blown heater core
Old Jun 6, 2008 | 04:10 PM
JYD84Berlinetta's Avatar
Ok, so heres my situation. I live in Windsor, Ont, Canada and drove to London, Ont today for a car meet. Got pulled over doing 120km/h in a 100..blah blah blah. Ok, thats alright..I can fight that. NOW to add insult to injury, as soon as I stopped into the hotel BOOM! The heater core gave out. Coolant all on the inside of the passenger floor.
Does anyone know any by-passes I can do? I need to just get home, it's about a 2 hour drive.. I know of a by-pass..well sort-of but not sure what lines to do, and how to do it. I have a 1984 Berlinetta with a 2.8L v6.
Old Jun 6, 2008 | 05:38 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: HELP!! Blown heater core
the 2 hoses going in to the fire wall u can clamp a piece of pipe or something between them. i forget what size offhand.. $35 at most for a new one. few simple tools for replacement an hour tops..
Old Jun 6, 2008 | 05:46 PM
Alright, sounds good. Thats what I was thinking. Thanks for the quick reply!
Old Jun 6, 2008 | 06:32 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
5/8" to 3/4" adapter pipe.
Old Nov 22, 2009 | 11:52 PM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
I was able to use the smaller hose straight from the block (inlet hose for the core) and go right to the rad, took a bit of finessing, but is possible.
Don't force it and watch that it doesn't crease or fold under the inlet tube on the rad. My 88 has an older motor, but this shouldn't make a difference, still the same sizes hoses for in and out of the core.
Good temp fix if you are out and can't get any parts.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
ndndndnd
Sep 28, 2015 08:00 AM
