ac problem help please
Old Nov 19, 2009 | 07:34 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Transmission: auto & t5
the problem is my ac only blows out the windshield defroster not out of the vents. cant figure out what is wrong any help with this problem would be great help. thanks in advance.
Old Nov 19, 2009 | 07:49 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: ac problem help please
sounds like there's no vacuum to the diaphragm. make sure the vacuum line is connected to the intake manifold and is not broken.
Old Nov 20, 2009 | 09:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
also check for vacuum leaks behind the heater control panel in the car - sometimes the selector switch goes bad and has to be replaced.
Old Nov 23, 2009 | 12:02 PM
slia67's Avatar
For safety reasons ( to clear windshields in cooler climates) if you loose vacuum to the heater controls, it automatically defaults to defrost. So check both your control unit and your vacuum lines like the other posters have suggested.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
