Summit Direct fit Rad my ***.
Old Jun 7, 2008 | 07:42 PM
WhiskeyChick's Avatar
Car: 1987 Trans Am GTA
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
First I know that there is some MINOR mods you have to do to your car to get it to fit.
But the fact that I had to actually hack the Summit rad is inexcusable.
I hammered the pass side of my inner fender well to allow the lower rad hose to slip over the inlet of the rad. I hacked the little rubber stops on the bottom of the rad mount hole so the rad would sit flat on them. I also cut our pieces of my stock rad mount plastic piece so i could still mount up my dual fans.
However i get to my upper rad hose and find an issue. The inlet on the rad is about 2 inches WAY to long. It kinks the hose and pushes it back into the AC pulley.
As you can see the summit inlet sticks out about 2 inches past the stock inlet at the bottom of the pic.
Soooo I just cut 2 inches off my nice new direct fit rad.... right.
This is more of a rant then anything cause kinda pissed about it. I dont think they should call there rad DIRECT fit, because its BS. I should not have to go to that much trouble.
PS. It is in the car, and everything is hooked up. Just miffed.... Still is nice looking though.
PPS Anyone with Air Conditioning on the drivers side of your car be prepared to have to do this to your own rad. Its not direct fit, not even close.
Old Jun 7, 2008 | 09:20 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Summit Direct fit Rad my ***.
In my reading on here, I've noted that there is no such thing as direct fit. EVERYTHING needs to be trimmed, bashed, cut, new mounting points etc.
Old Jun 8, 2008 | 12:16 AM
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
lol I know, but I checked every post I could search on here and didnt fine anyone who had to actually cut the rad. Just had to mod their car to get it to fit, and make a custom top cover. (I got my stock one to fit with minor modding)
Old Jun 8, 2008 | 12:08 PM
ZSC91's Avatar
I'da cut it like you did man. You did the right thing, i recently replaced mine and the transmission lines didnt fit ahah, took two adapters, white tape and a sealant. talk about direct fit radiators these days...
Old Jun 8, 2008 | 03:56 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
Nothing bolt on is ever really direct fit bolt on
you should see what custom engineering I am going through for my direct fit bolt in racing seats
CG
Old Jun 8, 2008 | 04:31 PM
Stevo's Avatar
Car: Pair of 92 Z28s
A bolt on never is...
I have one of those summit "direct fits". Amazingly i was able to use my stock upper mount but had to move all the holes for it. My fans rubbed also i managed to get it to work. I did a lot of trimming to the lower support to make it all fit right. I had to run a TBI rad hose with it trimmed to fit also. The lower hose actually went on fine for me, it was tight and its close to the frame but it worked. I dont think i was able to use either rubber bushings on the top or bottom but its very secured and doesnt rattle so i wasnt worried about it.
I got mine used for $150 and it has worked great keeping this new motor cool.
Old Jun 8, 2008 | 05:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
usually you have to trim the upper mount, clearance the frame, trim for the petcock valve, i didn't have to mess with the upper hose connection at all.
but like above, rarely are "bolt on" parts truly bolt on.
Old Jun 8, 2008 | 06:23 PM
Stevo's Avatar
Well you and i both probably have different thermostat housing, i think mine is a 45* angle? I never had to clearance the frame but ya i did have to trim the lower part for the drain petcock.
Old Jun 8, 2008 | 07:03 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Here's my Direct Fit Griffin
Ya, Rite
Old Jun 8, 2008 | 08:20 PM
ZSC91's Avatar
haha the only reason i had to replace my radiatior was because the FAN made a HOLE in my radiator, no playin, yall want a picture? ALL of the bolts came out of the fan sumhow and it bumps up and down and keeps makin a hole...But a quick stop at my local hardware store and 450.00 later came home with a buncha upgrades, my new radiator and fittings, and loads of sealant :P I'll stop now haha
Old Jun 8, 2008 | 08:33 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
u abelieve the direct fit be cool unit actually might be the only bolt in direct fit.
Old Jun 8, 2008 | 09:17 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Ya, Rite
How was the Griffin for a direct fit. I have been thinking of their for my car.
Old Jun 8, 2008 | 11:24 PM
jaykar's Avatar
Not a direct fit, but with a little fabbing not a big
problem.
Unless your going with a replacement radiator your not going to find one with extra cooling that doesn't require
a little work.
If your going to run AC with a thicker core which adds tubes or larger tubes its a little harder. Going to have to bring the rad in to make room for the grill denser, as I call
it, and play with the bottom saddle mount.
HTH
Later
Frozer!!!
Jan 19, 2024 04:55 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
Keith5
Aug 27, 2015 04:37 PM
LilHot
Aug 23, 2015 09:36 PM
