sending unit wire
Old Jun 16, 2008 | 09:07 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
sending unit wire
hey, my camaro has a temp guage, but there is no wire connecting the sending unit to the guage.
where should i look for this wire?
Old Jun 16, 2008 | 10:22 AM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Re: sending unit wire
Left side of engine, just behind the first spark plug. It is a one wire connector. I think it is green. The wire should be somewhere in this area. I think it is in the same bundle as the O2 sensor. It goes down along the cross member and past the engine mount.
Old Jun 16, 2008 | 03:42 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
i see the sending unit no problem... the wiring has been all hacked up though, and i cant find it.
thats why i asked if anyone knew where to find a new one.
Old Jun 17, 2008 | 03:49 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
What kind of car is it? Engine? Start at connector C100 at the fire wall (the big one) and find the wire and trace it as far as you can then splice in a new wire and connector. Look here for the wiring diagram. I think they are all dk green.
http://www.austinthirdgen.org/index.php?pid=19
Old Jun 17, 2008 | 10:23 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
well i found a wire, and connecter, spliced it in, and come to find out, the guage is broken or something.
cycles to full high when i turn the key 3/4 to start, but goes back down to low.
same thing with wire connected as disconnected.
Old Jun 18, 2008 | 09:08 AM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
It is common to peg the gauge on start up. What does it read after you start? You can try swapping gauges. The gauge can be removed without taking the cluster out.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
