Getting hotter while driving
Old Jun 23, 2008 | 08:31 PM
StreetRod's Avatar
Car: 89 Supra
Engine: Tbi 350
Well I got a quick question. Its not really that big of a problem but its just kinda bothering me. It cools fine at idle the fan kicks on for a few secs cools down like its suposed to do. Driving in the morning or later at night the temp runs around 170-180. This is on my project car that has a aftermarket alum radiator 2 row 1" flute its around 29" Long x 2.5"Thick x 19" Tall, has adjustable temp for fan control, has a 16" elec. fan I think, has a 160 degree stat. the correct size hose going to and from the engine block. But the problem is when it gets anywhere from 85-95 outside and cruising down the road it can climb over to 210 sometimes if not a little more. The car didn't orginal come with a air dam but i built one to see if it would help when driving. i think it did a little. I'm using a used water pump and going to replace pretty soon to see if it helps. The engine is a stock 350 out of a 95 truck with tbi. And the rpm at cruising speed is around 2400-2500 happens when you have 4.30 gears and 235-55-17. So could the pump just be worn out and not able to move the coolant good enough going down the road?
Old Jun 25, 2008 | 01:05 PM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Re: Getting hotter while driving
Just a few thoughts. First, make sure your water pump is for your block. Truck motors may not use reverse rotation pumps like many F-body's use. Also sounds like you might have an air pocket in your cooling system. Make sure your system is purged. Good luck.
Old Jun 30, 2008 | 11:57 PM
83Z28406's Avatar
Car: 83 Z28
Engine: 400
Transmission: Th 350
Axle/Gears: 3.27 9 bolt
I Had Major Problem With Aftermarket Fans I Will Never Use One Of Those Again Even A Stock Single Way Outflows Those
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
