AC rapidly clicking on and off
Old Jul 1, 2008 | 01:24 AM
Raiden's Avatar
I recenlty noticed my AC clutch clicking on and off rather fast. It clicks every 15 seconds. My AC runs cool, not cold. Is it my switch or is the level of my R12 low? I've never charged my AC system and I've never had a problem with my AC till now.
I ran a jumper on my low pressure switch and the rapid on/off stopped and the AC clutch stayed on the entire time the jumper wire was in.
My question is what is the probem? The switch? Or low coolant?
How do you change the switch? When you swap out the low psi switch, will it let out all the R12?
I did search with little results.
thanks for the help
Old Jul 1, 2008 | 01:31 AM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Re: AC rapidly clicking on and off
Sounds like you are just low on freon, and the switch is working properly. Don't run it when it is low on freon with the jumper or it could cause damage to your compressor. Better to get it recharged then swap it all out. If you are running R12, I hope you have a license to get it, that and its about 50 bucks a can.
Old Jul 1, 2008 | 01:38 AM
MADMAXGTA's Avatar
Car: 89 TTA
yea its just low.mine was doing that,added 1pd of r12 and she quit clicking,blows @ 34 degrees. cost me 65$ with labor
Old Jul 4, 2008 | 03:58 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
I agree it sounds like you are low on freon. Most shops still carry it so you can get it recharged with little to no hassle.
Old Jul 4, 2008 | 10:04 PM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
thanks for the help
Can you post a pix of this jumper? I've always heard of it but never seen it and I'm curious to see it. Sorry, my imagination isn't that good that I can read it and envision it.
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
meeklay812
Oct 1, 2015 03:46 PM
