original wire setup for electric fan on 84 305 trans am??
Car: 84, 99 Trans Am
Engine: 305 G, LS1
does anyone have a picture of how the original electric fan wiring went on an 84 trans am 305? when we bought the car years ago the wires were cut and put on a switch to run all the time. we are wanting to hook the wires back the way it was suppose to be so it will come on and off when needed. we found two wires close to the back driver side but it has no power so we don't think that's it. the car gets a little hotter when we shut it off and will take a little while to start do to this. i think the original setup would allow the fan to continue to run after the engine was shut off to help cool it down. anyone have pictures of how the fan wires run and where to?
Engine: 305 G, LS1
Re: original wire setup for electric fan on 84 305 trans am??
i believe the L69. i know it was the top of the line H.O.
it is L69, I just checked.
Last edited by 99transamgirl; Jul 14, 2008 at 01:25 PM. Reason: Automerged Doublepost
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
There should be a green wire from the fan relay to the fan switch in a cylinder head (probably passenger's side).
The original setup does not run the fan past the time the key is shut off. When the key goes off, the fan does too.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The fan switch is in the passenger side head.
[QUOTE=Apeiron;3823246]The fan switch is in the passenger side head.
Doh!...that was what I was thinking, just wasn't what I typed...
Engine: 305 G, LS1
thank you. I'll look for that in the morning. we're just tired of always having to turn a switch on. we usually turn it on as soon as we start the car so we don't forget and it runs all the time. I'd rather it not run if it doesn't need too. thanks
Engine: 305 G, LS1
is this it? this is the only wire I find that doesn't go to anything. I looked and there are no green wires or blue just sitting around that aren't all ready running to something. no cut wires anywhere either, other than the two black ones we found on the driver side but they don't get power at all.I traced the wire from the switch that is in the block and it runs behind the manifold over to the driver side and into a plug that is all ready hooked up. ???
Nope. That one is for a hood light, if your car is equipped for it.
The fan switch is on the passenger side cylinder head. It is roughly between cylinders #6 and #8, although since your wiring has been modified, the switch may be there, but the wiring may not.
The fan relay is along the firewall, on the drivers side of the car, outboard from the brake booster. The green wire that comes off it needs to go to the fan switch. That wire will activate the fan anytime it is connected to ground, and the key is on.
Engine: 305 G, LS1
thanks, that helps a lot. I found the switch in the head. I'll look again tomorrow on the driver side for the other part. nice to know what that plug goes to now.
If you can find the wire from your manual fan switch, you have found the wire that needs to be connected to the switch in the head.
You can, in fact, leave the switch connected to it. If you connect that wire to the cylinder head switch, and your manual switch, it can be activated by either of them.
Engine: 305 G, LS1
thanks guys. i think I'll have to leave it as is. I have searched everywhere and followed the green wires etc. and everything is all ready hooked up to something else. no green wire just hanging around. I see the switch on the head but it has a blue wire. even followed that one and no luck. the driver side has a green wire hooked up in the head but that's it. no where to hood it back up to. our fan has two black wires that had been run along the driver fender to the overhead console originally and now is a switch under the dash. thanks though.
Engine: 383 Carb
Transmission: 4L60
You're not running the fan current through that switch, are you?
Engine: 305 G, LS1
Sorry, I'm not much on the electrical stuff. my husband had put a switch with a 35 fuse built into it, I think 35, and when we turn on the car we just push the switch to the on position and it runs. that's kind of how the previous owner had it except they had it just wires in the overhead console directly to the overhead light and a switch with no fuse. it would get very hot and burn the switch out also had to replace fan motor. that's all I know. I mainly do a lot of work on replacing parts etc. but have never been one for the electrical stuff.
Engine: 383 Carb
Transmission: 4L60
You really don't want to run all that current through the switch like that. You need to use a relay.
Engine: 305 G, LS1
how would I go about doing that? sorry I seem to not know much about this.
Engine: 305 G, LS1
is this the relay on the driver side by the firewall? I found a picture of one on advanced auto parts and it looks the same. If so how do I hooked it up to the fan? thanks
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
A relay is simple to hook up.
a 4 pin relay has the needs hooked up as below:
pin 30 - plug this into the + side of the fan
pin 87 - plug into + side of battery (fused)
pin 86 - ground
pin 85 - plug into 1 side of switch
Switch pin 1 goes to pin 85 on relay
pin 2 goes to + side of battery (fused)
On the switch pin 2 can either be constant power (this means that the fan can be turned on at any time) or it can be put on an ignition only power (this means that the ignition has to be on to get power) I always use a 30/40 amp relay
pin 86 - ground
Engine: 305 G, LS1
is this the fan switch? it's on the driver side head and has a green wire
the one on the passenger side is in the block. I saw a picture of the knock sensor at advance auto parts and the passenger side looks like it just mine was painted black when the engine was done
. these are the only sensors on the side of the heads or block.
. these are the only sensors on the side of the heads or block. Moderator
Engine: 383 Carb
Transmission: 4L60
The first picture is the gauge sender, the second one is the knock sensor.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
the fan switch should be above the knock sensor in the exact same spot as the temp guage sender on the driver's side head, just turned around to fit on the other side (the heads are interchangeable).
Engine: 305 G, LS1
I guess it's been taken out then. the only thing I saw above it was a plug in the head. there are no other parts going into the head or block other than plugs. thanks
It's extremely unlikely it was taken out and replaced with a plug. That would have involved 'work'. The LG4, without electric fan, would have a plug in the head. Vin H in 8th place?
Engine: 305 G, LS1
we have ( or had ) the L69 engine code. in the exact spot is a hex shaped bolt that can have a tool inserted in it. it is in the exact location of the one on the driver side just by the 6 and 8 plug. I looked again and there is nothing else that goes into the engine block or heads. we got a new block but kept the heads. i know the previous owner said a lot of work had been done to the engine of the car to make it more of a hot rod when we got it. the fan wires were cut and run directly into the upper console to run constantly. they believed the engine had been bored out before. there is defiantly nothing in that spot other than that plug.
Pull the plug. That's where the temp switch should go.
Engine: 305 G, LS1
thanks, I'm glad I finally got that. Now i just have to buy one. I believe the relay is still attached on the firewall. I'll just have to have my husband figure out how the wires go to the fan. wires had been cut, chopped and rerouted all over the car when we first got it. not sure if they were put back in the correct location when we had the engine redone. thanks
Constant hot power wire to the relay should come off the always hot starter post. If the original switched 12volt control voltage wire is gone, one can be pulled from one of the other relays adjacent. The control ground lead can go back through the wiring harness over the pass side valve cover following the knock sensor wire to the switch. Power lead to fan can tuck into the harness that runs along the driver's side frame rail although I've seen other models where it wrapped around on the other side.
You want to pull at least #10 wires for your power and fan ground (which can terminate at the nearest ground point on the frame). The amp draw will exceed 20 amps on start up so a standard automotive type 20 amp fuse won't work. The factory used a fusible link which is basically a cheap slow blow.
does anyone know what color wires go to the wire harness that lugs into the fan relay? My markings rubbed off & theres ABCD labled on the socket the wires lug into!
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I want to Verify that the relay shown, is in fact the Fan relay as it pertains to my 1984 L69. I have two other identical relays but I don't know for sure what they go to as I wired my own in-tank 255lph fuel pump (Swapped tanks, original pusher in-tank pump was dead) and have no way to now verify that this indeed was for the fuel pump. Also, I have no provision for a "fuel pump" fuse, even though I have a spot marked for it on my fuse box. The slot is empty and can't accept a fuse.
colton_carlson
Mar 8, 2019 12:21 PM
