305 TPI overheating
Old Jul 23, 2008 | 11:34 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
305 TPI overheating
well, i had a problem a while ago with overheating and found my fans wouldn't turn on, i got it fixed but lately started overheating again. With radiator cap opened and revving the motor i can see movement of coolant so water pump should be working. When it got to 240 i checked and both fans were working but i noticed there wasn't much fluid in overflow tank. I went ahead and slightly popped the radiator cap(it's one of those safety ones that don't open all the way with first turn) and boiling fluid immediately filled the overflow tank.Could it be that thermostat is stuck closed or clogged radiator.
it's 89 firebird with 305 TPI dual electric fans
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
