Overheating Issue
Old Aug 31, 2008 | 10:52 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Overheating Issue
My car is having an over heating issue that I cannot figure out. It can be driving down the road and the temp stays fine as long as the car is moving. However, when im sitting in traffic or at a long stop light the temp will get higher and if I sit there too long the car will always overheat. Then, if I get moving for a while the temp will go back down to normal. What are some things that it could be, water pump?
Old Sep 1, 2008 | 08:31 AM
Zralou's Avatar
Re: Overheating Issue
Sounds like a fan problem.
Sara Lou
Old Sep 1, 2008 | 11:50 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
The fans dont come on in the car. Im still trying to wire them up (single to dual fan swap). The car just gets too hot too quickly which makes me think that it is something other than the fans causing it to happen.
Old Sep 1, 2008 | 12:14 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Just rig it up to run all the time. Then you never have to worry about if its coming on or not.
And if your fans arent working... then im pretty sure its your problem. My car did the same thing, dropped it off at the shop, gave em 20$ and they rigged my fan to run 24/7 and works perfectly, I could leave the car running in my driveway all day and it wont overheat.
Old Sep 1, 2008 | 05:50 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Ill have to figure out how to get the fans working now. I just bought a Hypertech Cool Fan Switch also.
Old Sep 1, 2008 | 05:57 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
my car was running hot and i took the rad out and cleaned all the dust and bugs and dirt that was stuck in the core and now its fine probably not your problem but its something to check out
Old Sep 1, 2008 | 06:17 PM
Zralou's Avatar
Running your fans "24/7", is not good for them, it will cause excessive wear and premature failure. it can also impede airflow at higher speeds, causing it to run hot.
If everything is setup correctly, you should only need your fan(s) in slow moving/stationary/idling situations.
Sara Lou
Old Sep 1, 2008 | 08:38 PM
5thFbody's Avatar
Car: 87 LT bird,82 Trans-am
Engine: 305,383
Transmission: auto
Axle/Gears: 10 bolt 2.73,323
I would check the water pump propeller after you get the fans wired. Have you taken a look into the radiator to see if its corroded at all? I would wire the fans on a switch you can control. If you need help I can guide you through it.
Old Sep 1, 2008 | 08:43 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Well please post the guide to running them on a switch inside the cab. This guy is coming tomorrow to help me pull the motor, maybe ill switch to dual LS1 fans and set up a switch inside the cab and just switch it on and off as needed.
Old Sep 2, 2008 | 08:44 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
The radiator doesnt look to have any corrosion inside of it. The core seems to be pretty clean also.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
