flex fan question
Old Sep 28, 2008 | 11:53 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
flex fan question
this isnt really a question for myself cause i would never run a flex fan but anyway lets not get me started. a guy at work has a 86 t/a that had a elec. fan and he had it on a switch and well for some reason wanted to go to a mechanical fan. i gave him the old shroud from my 82 since im running a elec. fan on it now and he bought a 19in flex fan from autozone and now he cant get the hood to shut without it pushing down on the shrough. he claims that he needs my hood now which i know is bs since i looked at both my 82 and 86 and the undersides are the same. anyone got an idea as to why it is hitting? i havent gotten to go look at his setup yet but i think he just installed something wrong. well thanks for the help in advance.
Old Sep 30, 2008 | 12:12 PM
Screamin86's Avatar
Re: flex fan question
anyone got any ideas to whats going on?
Old Oct 3, 2008 | 02:22 PM
phillyterror's Avatar
Car: 85' T/A
Engine: 5.7 350
Transmission: 700r-4
Axle/Gears: 9-bolt Borg Warner
I got 85 T/A with a flex fan, it has 18 inch on it and barely make's it!
I don't know how 19 inch would make it? I opened my hood an saw grove's
in the hood from the fan.
Plus; are you running a clutch? The closer you are to the slope of hood, the more likely in going to hit. a clutch, plus the adpater will make it hit. Also make sure you don't have a long nose water pump.
Go luck.
Old Oct 4, 2008 | 09:01 PM
Screamin86's Avatar
well he says when he shuts the hood the hood hits the shroud which cause's it to hit the fan and he is not running a clutch
Old Oct 7, 2008 | 08:34 AM
Car: 85' T/A
Engine: 5.7 350
Is it the orginial engine? but try a small fan. to keep the same amount of air flow. try using a fan with bigger blades. If that don't work; go to home depot, get a piece of 1/8 steel, make a new fan shroud... what don't exist, can be created. unless his trying to keep it orginial. Also double check the hood lines; something may be off there.
Old Oct 7, 2008 | 12:14 PM
Screamin86's Avatar
hs car is a 86 it cme with a electric fan and he wants a manual old style fan. car has carb lg4 305 in it i gave him my shroud from my 82 and he bought a 19in flex fan from autozone and they told him it was the one for a 84. he still thinks he needs a whole new hood to make it work.
mhatfield 14
Oct 24, 2015 07:48 AM
krisner89
Oct 10, 2015 06:03 AM
gixxer92
Sep 1, 2015 04:32 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
