HVAC vaccumm line routing
Old Oct 5, 2008 | 12:31 AM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
I'm having a problem with my heater controls. When placing the switch to any position, the air only comes out of the defrost. After a while and tinkering with the switch back and forth ever so slightly, the air ducts will finally come out of the vents and floor. I've traced all the vacuum lines out except for the red one. I don't know where this one goes. Can anyone point me in the direction to look, and also does any one know where I can get the vacuum lines? While troubleshooting this problem I cut the lines off the plug and individually put them back on the valve on the back of the control head. I think my problem lies in the valve itself. When I place the control to vent we'll say, I can here a hissing and if I squeeze the valve on the left corner a little bit, the hissing stops and the doors will open and close as normal.
Old Oct 5, 2008 | 06:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: HVAC vaccumm line routing
Defrost is the default for a vac leak. From your description, I'd guess the problem is the switch. Check the following link for more info:
https://www.thirdgen.org/forums/inte...ht=control+vac
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
gta892000
Sep 16, 2015 12:37 AM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
