New water pump new leak
Old Oct 9, 2008 | 01:55 PM
ricardomwilson's Avatar
I have a 92 firebird with a TBI 305 V8 Code E. I just finished installing my water pump and I poured in new antifreeze and it leaked out right away. The new water pump only had 2 bolts in it and a outlet for the lower radiator hose, I put sealant around the bolts with the gaskets and I connected the lower radiator hose very tight. And now it leaks heavily. Has anyone had this same problem before? When I look under the car I see only drips coming from the bottom of the timing chain area which is right under the water pump. Any suggestions?
Old Oct 9, 2008 | 03:28 PM
bunkie21's Avatar
Re: New water pump new leak
Dont SBC waterpumps have four bolts?
Old Oct 9, 2008 | 03:32 PM
Yeah, my bad 2 on each side, 4 total
Old Oct 9, 2008 | 03:46 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
If you didn't remove all the old gasket material off the engine block, then it will leak.
Old Oct 9, 2008 | 04:28 PM
firebirdman's Avatar
Car: 89 Firebird Formula
Engine: 305 tbi
Axle/Gears: 10 bolt 3.42
If you didnt clean the inside of the hose befor installing that can cause leaks. I would run it then crawl under and locate the leak.
Old Oct 9, 2008 | 06:54 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
just how tight did you connect the lower rad hose? If you really tightened the hell out of it you may have put a hose in the hose with the clamp, or cracked the pump it self..
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
