Metal hoses
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Metal hoses
Has anyone ever used G sport metal hoses? I was wondering because I think they would look better than the factory hoses. If people used them, did they like them and which ones did you get for a tpi? I might give these a try because unless you go to all AN fittings, you can't get real braided hoses, so I guess this could be my next best options.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Metal hoses
I thought real braided hoses are ONLY available in pure AN setups?
I'm curious about your question as well though, so i'm tagging on.
Car: Firechicken
Re: Metal hoses
Why did I put G sport, it is actually G Flex. They are made by Mr. Gasket. My bad.
Car: GM
Engine: v8
Transmission: slushboxes
Re: Metal hoses
I know what you are talking about, I used to see it at a local speed shop but I think that it is discontinued, cause I can't find it anymore. The closest I found was this.
http://www.jegs.com/p/Spectre/762574/10002/-1
I don't know why but that doesn't look very durable. It looks like cheap aluminum, and it looks like it might restrict the coolant cause of all the bumps in the hose. I don't know though, it looks kind of bad but I may be wrong, I'll keep my eye on this one to see if anyone has tried these.
Car: 1991 RS Camaro
Engine: 350 0.060" over
Re: Metal hoses
^^^ That isn't braided though. I agree that it looks cheap, and I think it will look bad under the hood as well. I wasn't aware that you could get non AN fitted braided hoses for this application.
http://moesperformance.com/index.php...aa37df0f94f4b9
There's the g-flex ones.
If you are just after the looks you may be happier with something (in the right size) like these:
http://www.sfxperformance.com/parts/SPT6008B.htm
http://www.sfxperformance.com/parts/SPT7496.htm
While I understand non functional vanity covers are common in the car world, it still reminds me of the phrase "Lipstick on a pig".
Last edited by jccaclimber; Oct 22, 2008 at 08:00 AM. Reason: Automerged Doublepost
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: Metal hoses
Nothing cheap about it. G-Flex is stainless steel and is available in powder coated finish.
I'm running it on my car and have been happy with it. Here's some pics of my set-up just before I finished the radiator install.
Car: Firechicken
Re: Metal hoses
What about the lower hose to? I wanted to know if it would work on that bigger hose.
Car: GM
Engine: v8
Re: Metal hoses
I don't see why you couldn't use them on the lower hose if they make a diameter big enough. I should get these for my car. It would look so cool if they came in a polished silver or chrome look. Red is ok if everything else is red, otherwise, it looks *****'d.
Car: Yes...
Re: Metal hoses
http://www.jegs.com/p/Mr.+Gasket/755208/10002/-1
Last edited by BretD 88GTA; Oct 29, 2008 at 04:44 PM. Reason: Automerged Doublepost
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Metal hoses
i used this stuff for my upper radiator hose, i used black. After i installed it, i really didnt like how it looked and took it back off. Im still looking for an alternative.
Car: GM
Engine: v8
Re: Metal hoses
Because it is metal, I suppose that it could shed heat faster through the ripples and fins. I want to know more about this before I buy it cause it looks to be quite expensive.
Pac J
May 17, 2020 10:44 AM
MrPackstin
Oct 25, 2017 08:09 PM
sjorgens
Oct 1, 2015 07:54 PM
