Hood Insulation and Rear Hood Seal, Yes or No???
Old Oct 27, 2008 | 04:00 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
how much hotter are the underhood temps with the insulation installed? Im wanting to put it back in so i can cover up the messed up paint under the hood, but if it raises the temp alot i will repaint the under hood
also i know its an old hot rodder trick to remove the hood seal in back to allow some of the hot air to get out, anyone notice a difference on there 3rd w/o it, i know it worked on cars i have done it to in the past
Old Oct 27, 2008 | 05:08 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Hood Insulation and Rear Hood Seal, Yes or No???
jason , the hood pad is there for sound insulation only , not heat . the rear seal on the hood keeps eng. fumes from getting into a/c & vent inlets . ( the screened inlets by the base of the wiper blades ) you will really notice it in the summer with a/c & stop & go traffic . i found out the hard way . good luck .
Old Oct 27, 2008 | 07:41 PM
89RS_82Z's Avatar
hmmmm................well...... i need something under there or i need to repaint it
never had the fume problem on my other cars i did that to....i dont think im doing it to the camaro, as i run the AC alot in it
colton_carlson
Mar 8, 2019 12:21 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Randomtask2
Aug 13, 2015 01:57 AM
