Different a/c delete box
Old Nov 4, 2008 | 02:47 PM
epsmotorsports's Avatar
i have a 91 camaro that i removed the AC in and bought an AC delete box, my question is are there different boxes? The one i bought i cannot reuse the blower motor and the connection is different. the blower motor that came with it is not as long. the box though fits in perfectly.
Ideas?
Old Nov 12, 2008 | 12:06 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
Re: Different a/c delete box
The A/C motors are larger than the A/C delete motors. You can purchase both the A/C delete motor and new squirl cage at Advanced auto or Auto Zone. The motor is like $25.00 and I cant remember how much the squirl cage was but it was cheep as well. The A/C delete boxes are the same.
Old Nov 12, 2008 | 01:07 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by epsmotorsports
The one i bought i cannot reuse the blower motor and the connection is different. the blower motor that came with it is not as long. the box though fits in perfectly. Ideas?
You can use any blower you'd like, the connectors are irrelevant, just rewire everything like I did. I used an A/C delete box from a G20 van, and a blower motor from an entirely different vehicle (I cut the connector harness along with it), but with the right size cage. I reused the stock AC resistor from my car to retain all four speeds, hooked it up to the main harness, then spliced it into the new blower motor. I get all four speeds, no problem....
https://www.thirdgen.org/forums/fabr...tml?highlight=
Old Dec 14, 2008 | 10:02 PM
T TA 355's Avatar
What year g20?
Old Dec 14, 2008 | 11:12 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Mid-late 80's is what I got mine out of, and the similar year S10's used the same box. You have to do a couple of things to make it fit https://www.thirdgen.org/forums/fabr...want-c-so.html This should help you out if you go the G20 route. James
Old Dec 15, 2008 | 03:17 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I have the American graffitti AC Delete box, cost me $170 new, and will sell (never installed) for $85 shipped. Full fiberglass and is smaller than the 1LE Delete box in depth and height, Depth mostly, as the 1LE box is bulky where the air goes into the car where as the AG box is smaller for more room in the engine bay.
They are found here.
http://www.acdelete.com/pages/82-92_F-body.htm
Let me know if you want it.
Old Nov 21, 2009 | 10:24 PM
T TA 355's Avatar
I need to find one, have most of my parts.
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
buckshot63
Sep 10, 2015 09:15 AM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
