89 camaro built 350 overheating
Old Nov 6, 2008 | 05:42 PM
don_11's Avatar
i have an 89 camaro with an built 350 motor i have dual fans blowing at 2000rpm each and a 3 or 4 flute radiator not sure this is a vortec 350 the motor was re built has a 501 501 cam it might have 600 miles on it i was rideing the other day and my temperature started to rise if i get above 60 it rose to about 210 normal running temp is 150 to 160 on a cool day im really kind of stumped because i dont have a thermostat in it plus my fans work and we changed the waterpump a few days ago but the pump wasnt new we had one that we had taken off the motor before we got it running right it needs new plugs but i dont know im clueless i need some help
Old Nov 6, 2008 | 05:44 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: 89 camaro built 350 overheating
Your fans are running the wrong way against the natural airflow I bet.
Old Nov 6, 2008 | 06:05 PM
don_11's Avatar
that was problem awhile back but i bought fans that only run one wy and ive been driveing it on a 39.7 mile comute for he past couple of weeks with no problem till just recently
Old Nov 6, 2008 | 09:41 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
150 to 160 is way too low of an operating temperature. 210 is absolutely perfect.
Old Nov 6, 2008 | 09:52 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
make sure your air dam is still there, go up front get on your hands and knees and look, you should see a black flap hanging down
i dont like to see my motor over 190, all the high heat is for emissions crap normaly...
put a 160 stat in it, i have heard of motors having to much coolent flow, that its going to fast w/o the restriction of the stat it dont have enough time to remove the heat....they also make water restrictors if you totaly dont what a stat
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
Reborn756
Sep 4, 2015 03:42 AM
mustangman65_79
Sep 1, 2015 03:51 PM
NWAsonoma
Aug 18, 2015 05:45 PM
