Volts drop low when fan come on.....
Old Dec 1, 2008 | 03:39 PM
Kngnthn76's Avatar
Does anyone know why my volts drop when my fan comes on? They drop below 13 and the rpms drop also. If my lights are on, they dim also. They will go back up after a few seconds or if I hit the gas.
Old Dec 1, 2008 | 03:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Volts drop low when fan come on.....
Perfectly normal.
Old Dec 1, 2008 | 03:52 PM
Kngnthn76's Avatar
Thank you...This is my first third gen so i am learning as i go.
Old Dec 1, 2008 | 05:12 PM
vette gator's Avatar
Car: 85 Z28
The fan takes a lot of current to run. You'll also see the same thing if you turn on the rear defroster. The worst case is sitting at a traffic light at night in the rain with headlights, wipers, windshield defroster and rear defroster all going at once while idling. You'll definitely notice that the gauge has dropped!
Old Dec 1, 2008 | 05:59 PM
Kngnthn76's Avatar
My rear window defogger doesn't drop my volts at all. But that might be because only half of it works. That's a search I need to do.
eightsixseven
Dec 16, 2024 01:50 PM
777Shock777
Oct 29, 2015 04:30 PM
jharrison5
Aug 19, 2015 05:53 PM
BOOT77
Aug 10, 2015 12:20 PM
