Over Heating issue *need a answer*
Old Dec 1, 2008 | 10:05 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Ok I have a new 160 thermostat, LS1 radiator, radiator fan running 100% all the time. the car is a 92 305 5-speed and I have the air dam and cleaned the ac condensor but still the car will break 220 with the heater on full blast. the temp will go down a little when I rev the engine. The last thing I have to replace is the water pump because everything else is new and I don't have a blown head gasket. Could it be the water pump not flowing enough water or something like that It has been replaced but not by me.
Old Dec 2, 2008 | 06:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Over Heating issue *need a answer*
Shot in the dark: Older thirdgens (and perhaps the new ones) had a spring in the lower radiator hose to keep it from collapsing.
JamesC
Old Dec 2, 2008 | 11:23 AM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
The hose isn't colapsing but I was driving it last night and it got up to the fist mark in about 10 min then on the way back it got to 220 and no higher. I am really thinking it might be the thermostat even though it is only like 2 months old because I have enough coolant and the fan and air dam are doing there jobs just the water pump or stat may not be.
Old Dec 2, 2008 | 03:05 PM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Problem solved it was the new thermostat I tested it and it wouldn't open a little till about 200 and even then it was barely cracked open. SO got it up to about 300 with a electric heater coil and it was about half way open and it started to change color from being super hot and wouldn't open anymore.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
TBRays98
Sep 6, 2015 05:05 PM
