Where is my fan switch?
Old Dec 12, 2008 | 08:08 PM
thisme305's Avatar
Car: 92 Camaro RS
Engine: 3.1 V6--454 BBC in the works
Axle/Gears: Stock 3.23
Im having overheating problems with my 92 RS 3.1 V6 and cant figure out where the hell my fan switch is. Or does it even have a fan switch? I had it straight wired but over time that melted my steerting column harness and ignition switch so thats out. I replaced the temp sensor and thermostat and still nothing. I think the fan relay is working but I will be buying a new one anyway. Any advice is greatly appreciated, thanks
Old Dec 22, 2008 | 04:12 PM
thisme305's Avatar
Car: 92 Camaro RS
Re: Where is my fan switch?
Anybody have an idea?
Old Dec 22, 2008 | 08:36 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Ok, here's what I found for the 3.1... It seems to indicate that the fan is controlled by the ECM, which gets it's info from the sensor "in the top front of the intake..." Which is probably the one you replaced already... Sorry I couldn't be of more help, hopefully someone can fill in where I left off.
Last edited by BlueIroc-Z; Dec 22, 2008 at 08:44 PM. Reason: Didn't notice the part about 3.1...
Old Dec 22, 2008 | 09:17 PM
thisme305's Avatar
Car: 92 Camaro RS
I really appreciate the help though. I guess Im gonna go ahead and order a new relay and if that doesnt work then Im gonna try the manual fan switch thing inside the car. If i do go that route would my service engine light come on?
Old Dec 23, 2008 | 09:19 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
KEEPING YOUR KOOL
Nope.
A manual fan switch will not make your SES illuminate.
I have a manual fan switch among other things.
Everybody that sees driver’s compartment calls it James Bond.
Anyway even with the switch, maintain the sensor control of the fan in case you forget to manually override.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Dec 23, 2008 | 12:32 PM
thisme305's Avatar
Car: 92 Camaro RS
Re: KEEPING YOUR KOOL
Thanks for the help!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
