temp gague intermediatly works
Old Dec 27, 2008 | 05:26 AM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
it seems that my temp gauge always works first time i use the car (when its fully cooled down) then until my car is completely cooled off
say i run into the gas station run out restart my car the gauge drops all the way straight down and will not work again until the car is completely cooled off
any ideas on whats causing this
Old Dec 27, 2008 | 07:29 AM
rallysport383's Avatar
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
Axle/Gears: 4th gen/3.55
Re: temp gague intermediatly works
Bad coolant temp sensor, guage malfunction, or wiring.
Old Dec 27, 2008 | 10:20 PM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
is their any certain way i can test the gauge to see if its that that is working or not...... also were is the temp sensor located
Old Dec 27, 2008 | 10:31 PM
SpeedMetalT/A's Avatar
Car: 87 Trans Am
Engine: L98 350 w/carb
Transmission: TH350
The temp sensor for the gauge is on the drivers side cylinder head. It could be bad I had the exact same problem with my car and it was the sensor.
Old Dec 28, 2008 | 06:10 PM
topradman's Avatar
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
wire can also get hot there especially if you have headers. check wire terminal for tight onto wire, clean terminal & make sure its snug on the sender. make sure ground straps to motor on back of heads are in place...probably not the guage.....good luck...
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Irocohio
Aug 12, 2015 08:03 AM
