over heating 88 camaro
Old Jan 15, 2009 | 09:07 PM
chevy Freak's Avatar
Car: 88 camaro
Engine: 305 TBI
Axle/Gears: not sure
what is the potential damage to motor when reaching 300 degrees? i wired up a toggle to the fan because the relay wiring was hacked up when i baught the car. i also took out the thermastat. it usually runs around 165 but today it was 6 degrees outside and i let it warm up to 120 before i drove off. i got on the highway and it took less then 3 minutes and my temp guage bottomed out which is 300. i imediatley shut the car off and coasted to and exit then all the water out of the overflow sprayed out. i need to know what i could be looking at for possible damage besides a blown head gasket and warping the the block. it was at 300 for about 2 minutes
Old Jan 15, 2009 | 10:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: over heating 88 camaro
Heads will damage before the block.
Old Jan 16, 2009 | 10:09 AM
Car: 88 camaro
Engine: 305 TBI
thanks for the info. it turns out i didnt even blow a head gasket
Old Jan 16, 2009 | 03:04 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I had a street car 350SBC which went well in excess of 300°.
I’ll never know because the gage was pegged.
The temp sender got so hot it became inaccurate so I replaced it, but that’s all I had to replace.
You should change the oil but otherwise don’t worry too much about it.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
mustangman65_79
Sep 1, 2015 03:51 PM
kyle5647
Aug 15, 2015 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
fonzie85
Aug 13, 2015 11:50 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
