Stock rad. hold up to Pontiac 455 engine?
Old Feb 2, 2009 | 12:36 PM
Gary Berg's Avatar
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
Hi, im doing a Pontiac engine swap into a third gen. The engine i am using is a 455. My question is can the stock rad. hold up to the flow needed for the 455 and will there be enough room for the engine to fit with the stock rad?
Old Feb 2, 2009 | 02:00 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Stock rad. hold up to Pontiac 455 engine?
I would think a stock radiator from a car with A/C or the Heavy Duty cooling option should work fine. 3rd-gens have a more modern aluminum core radiator that cools better. My '71 T/A 455 HO came with only a 3-core radiator from the factory.
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
