Best cooling fan switch and thermostat temp for stock setup
Subscribe
Mar 16, 2009 | 08:08 PM
Hope you guys can set me up with some info on the best cooling fan switch to get and what temp thermostat to run. I have had 3rd Gens for over 10 years and the only time I had to modify a cooling system is when I hot wired the fans back in the younger days.
So now, what is the correct way to do this? I know Jet has a fan switch for 195/185`F on/off. Is that it? Are there others? Also if I run a 180 Tstat will this work fine?
This will be on an L98 car with dual fans.
Mark
Reply 0
Mar 16, 2009 | 10:26 PM
Re: Best cooling fan switch and thermostat temp for stock setup
i use that fan switch and a 160 degree tstat(changing it to 180 soon)
but yah since i put that fan switch it it never gets higher than the middle of the guage...highly recomended
Reply 0
Mar 17, 2009 | 07:05 PM
Thanks, so what's the reason that you're switching to the 180 stat?
Reply 0
Mar 17, 2009 | 07:29 PM
it doesnt really allow it to get up to normal operating temp, especially for canada it is a little to low. if im on the highway the temp is just too low for my liking. and most guys on this site will say a 180 is a much better choice. i was just experimenting.
Reply 0
Mar 17, 2009 | 07:38 PM
i just knoticed ur in chicago...if your weather is anything like what most canadian citys get i would say 180 would be sufficient
Reply 0
Subscribe
