Damn fan switch
Old Apr 1, 2009 | 07:57 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Damn fan switch
Is the fan switch the same as the sending unit for the temp gauge? If not, what is the autozone part number for the temp gauge sending unit and pig tail? Thanks for the help in advance.
Old Apr 1, 2009 | 08:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Damn fan switch
they should be able to tell you, ask for a fan switch, if thats what you need, or a temp sensor, if thats what you need. they are 2 different items.
the temp sensor is on the driver side of the block, the fan switch is on the passenger side.
Old Apr 16, 2009 | 10:00 AM
91ZRocker!'s Avatar
Car: 1991 Z-28
Re: Damn fan switch
I have a sensor on the right side of my radiator about half way down. It isn't plugged into anything. Does anyone know what it is for?
Old Apr 16, 2009 | 02:27 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: Damn fan switch
fluid level sensor
Old Apr 26, 2009 | 12:02 AM
all4u's Avatar
Car: Firechicken
Re: Damn fan switch
There is nothing plugged into the sensor on the passenger's side! Darn it, I can't find any wiring that is unplugged. Can someone take a picture of the connector and wiring. I need help.
Old Apr 27, 2009 | 02:00 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: Damn fan switch
I just finished dealing with this stuff on my car. What year and engine do you have in your car?
Mine has the dual fan setup. The radiator fan switch on the passenger side between cylinders 6 and 8 is for the secondary fan. It causes the fan to come on at 235*. The plug has a single wire that comes out. I think the stock wire color is gray and it goes to the secondary fan relay.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
