Sensor
Old Apr 5, 2009 | 04:05 PM
19Maro91's Avatar
Car: Camaro
Engine: 305 TBI
Sensor
i have no power going to the sensor by the thermostat and need some help to find out where the problem might be
Old Apr 6, 2009 | 10:38 AM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: Sensor
do you mean the gauge on the dash board doesn't move?
Old Apr 6, 2009 | 11:36 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Sensor
To make things clear: the sensor by the thermostat is for the ECM, not for the dash gauge (that one is in the drive side head, between the first two spark plugs).
If you disconnect the connector from the sensor, you should be able to measure 5V DC across the two pins with the key on.
If you can't, measure it against a ground and also measure the corresponding pin on the ECM (whichever you might have - you failed to indicate that).
Hope this hellps.
Lou
Old Apr 6, 2009 | 12:50 PM
19Maro91's Avatar
Car: Camaro
Engine: 305 TBI
Re: Sensor
The gauge works but the fan doesnt turn on and my car ends up over heating. i replaced the coolant temp sensor and found out that no power was going to it and found a wire that wasnt connected but couldnt figure out what it went to and im thinking that this is the problem. its a green wire on the passenger side near the exhaust.
Old Apr 6, 2009 | 01:14 PM
BigBadLou's Avatar
Engine: TPI
Re: Sensor
If you have a TBI engine (you still haven't told us), the single green wire on the passenger side of the engine must be connected to the overheat switch in the head, otherwise you'll have no cooling at low speeds or stopped in traffic and your engine will overheat.
Lou
Old Apr 6, 2009 | 01:27 PM
19Maro91's Avatar
Car: Camaro
Engine: 305 TBI
Re: Sensor
its a 305 TBI. where is this overheat switch? using the AC to cool it down is becoming a problem
Old Apr 6, 2009 | 01:55 PM
BigBadLou's Avatar
Engine: TPI
Re: Sensor
The overheat switch is what you described in your earlier post. It's in the passenger side head between the last two spark plugs. The green wire must be connected to it for the cooling fan to cool the engine.
If you are using A/C to cool the engine, that means that the rest of your wiring is working fine, you just need to make sure that the wire is connected to the switch.
Lou
Old Apr 7, 2009 | 10:49 AM
19Maro91's Avatar
Car: Camaro
Engine: 305 TBI
Re: Sensor
thanks. ill see if i can get to and find it today
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
