overheating
Old Apr 13, 2009 | 03:46 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
overheating
When im driving, it gets right up around 210, and stays there. Even when im on the highway.
and it seems like my defrosters dont blow unless there on high. It looks like theres a little antifreeze on my lower radiator line, but not alot of it.
any sugestions?
Old Apr 13, 2009 | 03:54 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: overheating
210 isnt bad.When you start hitting 260 then be worried.
Old Apr 13, 2009 | 03:57 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: overheating
agreed....210 is actually factory where it's supposed to run....
Old Apr 13, 2009 | 08:25 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: overheating
really?
because it usually runs about 170 at all times, and it just started hitting 210.
Old Apr 20, 2009 | 09:51 PM
rvega022's Avatar
Re: overheating
The same issue is happening to with my 1986 IROC-Z, I noticed that my fan motor was running slow. I'll be looking into it this weekend, I'm undecided in replacing the fan motor or upgrading to an after market dual fan setup.
Old Apr 27, 2009 | 07:40 PM
rvega022's Avatar
Re: overheating
I had forgot to reinstall the plastic air dam, this weekend I reinstalled it. I took the car for a test drive and I could not get the car to heat up even in Miami traffic, it never went past 170 ~ 180 degrees.
Make sure you have your radiator air dam installed properly.
Old Apr 27, 2009 | 08:00 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
Re: overheating
mine is doing the same damn thing. put a new 180 stat in and its hitting 210. whats up with that? i have a mechanical fan not an electric
Old May 5, 2009 | 05:45 AM
GadeXTrigger's Avatar
Car: 91 Camaro
Engine: 5.7Fl V8 350 tpi
Transmission: 700R4 Automatic
Re: overheating
well you might wanna make sure you ONLY have coolant/antifreeze in it. if you have just water it will get real hot for no reason
hope this helped
Old May 5, 2009 | 09:28 AM
oil pan 4's Avatar
Car: 89 Firebird
Re: overheating
Make sure your cooling system is holding pressure.
That will make it get real hot for no reason.
Old May 16, 2009 | 12:47 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: overheating
i agree with the air dam comment.
it makes a huge difference.
i can completely disconnect my fans, and as long as i am going more than 15 mph, the car wont heat up past 160 or so (160* thermostat)
Old May 17, 2009 | 02:22 PM
99transamgirl's Avatar
Car: 84, 99 Trans Am
Engine: 305 G, LS1
Re: overheating
mine usually runs around 180-200 when the outside temp is around 70 or below. when the temp gets around upper 70's and above it runs around 210-220. and that's normal for it. has the outside temp gotten hotter where you are at?
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
