hot water valve delete, affect A/C
Old Apr 16, 2009 | 10:29 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
if i take the hot water valve (also called heater valve) out and go stright to the heater core from the intake and then from the heater core directly to the rad, will it affect the cooling of the A/C.....i got it ghetto rigged now and it still seems to blow cold, and the heat works when you move it to heat...i just havent got it out to drive to see if it will really hurt the A/C's cooling
<Car Stats
if it will cool w/o the vlave then its going bye bye, but if i need it for the a/c to work good then i guess i will need to put a W.T.B. post out for one
Old Apr 27, 2009 | 12:36 PM
Pocket's Avatar
Car: 91 Trans Am
Re: hot water valve delete, affect A/C
The valve prevents hot coolant from running thru the heater core when the HVAC controls are not on a 'heat' setting
When the AC is on the heater core is blocked by a vacuum controlled door. You wont notice the difference
Just be sure to plug the vacuum line that went to the valve or youll have a fun leak to track down
Old Apr 27, 2009 | 03:56 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I had done this on my 89 and and had good results. The A/C still worked well, may have been a couple degrees warmer than had I kept the valve, but nothing to really complain about. Plus it meant I could see a bit more of that engine hiding underneath
Old Apr 27, 2009 | 04:21 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
I just recently did this, and to prevent the hot coolant from flowing to the heater core in the summer, I put a simple 3/4" ball valve in between the manifold hose and the heater core. It is pictured below. It has the red on/off valve on it right in front of the heater core. Can pick one up from home depot for around $8.
Old Apr 27, 2009 | 05:18 PM
89RS_82Z's Avatar
well i said ef it, at the cost of the heater valve ($12) just keep it and reroute the lines to make it look better
lakeffect2
Aug 23, 2015 08:44 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
