Is my water pump going the right way?
Old Apr 28, 2009 | 12:29 PM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
on my 1989 formula i have a edelbrock aluminum water pump, when i bought the pump my car still had the serp setup on so im thinking its a reverse flow pump, now i have a v-belt set up on it with the same pump, the belt goes around the water pump the crank and the alternator, so can some one confirm my thought of the water pump now running the wrong way, cause it does seem run hot, around 220-230 with a 160 thermostat
Old Apr 28, 2009 | 01:22 PM
Stephen's Avatar
Car: 87 GTA
Re: Is my water pump going the right way?
You converted a Serpentine belt system to a V-belt system?
Yes....The Serpentine pumps are a Reverse Rotation pump, so I'm betting the pump you put back on, is turning the wrong way.
Old Apr 28, 2009 | 02:40 PM
Car: 89 formula
Engine: 305tpi
Transmission: t-56
yea i converted from a serp belt to a v belt, all i run is an alternator and a waterpump so it was easier and cheaper to do a v belt setup, thanks im thinking its going the wrong way i just wanted to make sure
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
