Throttle body cooling problem
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
On my 2.8 there are two hoses that go up the the throttle body for cooling. earlier i noticed the plate that mounts underneath is leaking. So my question is, as a temporary fix could i just bypass it by putting the hoses together? Would it hurt any thing? I mean how hot could it get with all the cold air going through it.
Its probably a noob question...
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Throttle body cooling problem
The coolant hoses to the throttle body are actually
there to HEAT the throttle body to prevent it from
icing up under certain cold weather conditions-
it's ok to bypass and connect the hoses together.
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
