[Resolved] Dual Fan TPI (Passenger Fan Always On)
Old May 14, 2009 | 09:13 PM
88IROConv's Avatar
Car: 1988 IROC Convertible
This car is original. I believe the passenger fan is the one that comes on when you flip the AC on. Correct? It runs whether the AC is on or not. So I'm trying to figure out what's making it think the AC is on all the time. I checked the relay mounted on the passenger side fender. It's clicking and working ok.
Now where do I go?
'88 TPI VIN "F"
Old May 19, 2009 | 01:17 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
FAN TALE
Make sure your control is not in the DEFROST position.
Make sure your FAN A/C PRESSURE SWITCH is not stuck in the closed position.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old May 19, 2009 | 03:35 PM
88IROConv's Avatar
Re: Dual Fan TPI (Passenger Fan Always On)
I'm not seeing a A/C fan pressure switch on the schematic. I see a heavy duty coolant fan switch on the passenger rear cylinder head. It says it closes at 238 degrees which trips the fan on. The only other thing I see is the heavy duty coolant fan relay which is working fine.
The control is in the off position. I have cycled it through all the settings and back to off again while the key was in the run position. Fan continues to run.
the shop manual says to pull the FP FAN fuse which I did and the fan turned off. If the fan stayed on it would be a bad relay. So I'm back to the fan switch on the cylinder head.
Where is this A/C fan pressure switch?
Old May 22, 2009 | 07:10 AM
88IROConv's Avatar
Resolved: My problem was the coolant fan switch in the passenger side cylinder head is bad. However, I broke the plastic connector that plugs into the sensor trying to unhook it. So now I'm SOL unless I can find another connector.
Old May 22, 2009 | 07:55 AM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Is that the connector that looks like the knock sensor connection (1-wire I believe)?
I was actually having the exact same issue prior to tearing my car apart. When I took the motor out, I found the harness was broken at the sensor.
You can get a pigtail at ANY parts store.
http://www.napaonline.com/MasterPage...ness+Connector
Old May 22, 2009 | 11:14 AM
88IROConv's Avatar
Re: [Resolved] Dual Fan TPI (Passenger Fan Always On)
Yes it's the 1-wire. Thanks a million for that link. That's exactly what it looks like.
Old May 26, 2009 | 12:32 AM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
You can get it at the dealer for about $20. They may not stock it though. I just checked on that about 2 weeks ago
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Sanjay
Aug 12, 2015 03:41 PM
