tpi cooling lines
Old May 31, 2009 | 02:09 PM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
tpi cooling lines
ok so i recently found out that the cooling lines that hook up to my throttle body are missing and i have no idea where im supposed to hook them up and what im supposed to get from the parts store so i can hook them up, i have an 87 firebird with a 5.7 tpi
Old Oct 2, 2013 | 10:57 AM
Mike89's Avatar
Car: 89 IROC-Z
Axle/Gears: 2.77
Re: tpi cooling lines
Hey did you ever figure this out? I just realized my car has the same issue...except the line next to the thermostat housing runs down to a funnel that's screwed to the air dam, and the one that comes out the passenger side is just a cut off hose.
Old Oct 2, 2013 | 04:56 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
One of the Pass side of the TB goes to the heater switch. The stock hose on the bottom of the TB is in the shape of a "U". Comes out of the TB, 180* to a nipple in the front of the IM.
Old Oct 2, 2013 | 06:29 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
You shouldn't need a TB heater unless you plan on driving when the temp is below zero. Their only purpose is to prevent the TB from freezing.
Old Oct 3, 2013 | 03:22 PM
Mike89's Avatar
Car: 89 IROC-Z
Axle/Gears: 2.77
Thanks Keoman. So is that all those hoses are is a tb heater? Why would the PO put that hose/ funnel deal on there - maybe some attempt at a cold air intake to cool the air going through the tb? Can I just cap these off to make it neater or is this rig actually doing something?
Old Oct 3, 2013 | 03:28 PM
Keoman's Avatar
Yes it is for heating the TB. If you are going to bypass it, I would suggest this route.
https://www.thirdgen.org/forums/cool...nt-bypass.html
You may run into problems in the sub 32* temperatures this way however.
Old Oct 3, 2013 | 03:35 PM
Mike89's Avatar
Car: 89 IROC-Z
Axle/Gears: 2.77
Great, thanks again!
LT1Formula
20
Nov 14, 2015 12:02 AM
mdtoren
Aug 23, 2015 12:52 PM
Sanjay
Aug 12, 2015 03:41 PM
Leggman1
Aug 6, 2015 04:15 AM
