tranny cooler
Old Jun 2, 2009 | 05:24 AM
monsterjam5000's Avatar
tranny cooler
whats a good trans cooler for a 91 camaro rs tbi 5.0?
Old Jun 2, 2009 | 06:44 AM
oil pan 4's Avatar
Car: 89 Firebird
Re: tranny cooler
I went to my local Advanced auto and got the smallest aluminum trans cooler they had and mounted it in front of the radiator with ADAL clamps from lowes and used the hose clamps and trans cooler line that were in the kit. I plumbed mine so it uses the radiators built in cooler and then runs through the aftermarket cooler and back into the transmission.
With a 180'F engine coolant thermstat, an added air-oil cooler and good air flow you wont have any transmission heat problems.
Don't use that cheap-0 mounting kit BS the kit comes with. ADAL clams are best.
Old Jun 2, 2009 | 02:26 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: tranny cooler
i used the hayden 679 from oreilly auto which is the same as the bigger imperial stacked plate cooler from advanced auto. tapped into the top line. out of the rad to the bottom of the cooler and out the top of the cooler to the steel line.
Old Jun 3, 2009 | 06:12 PM
Re: tranny cooler
i have never seen any body using the original cooler and an aftermarket one as well. thanks alot this is a lot of help.
when i do this to you have to bleed any thing?
Old Jun 5, 2009 | 06:13 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: tranny cooler
nope just make sure all is tight and start her up. then check fluid level.
Old Jun 6, 2009 | 10:04 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: tranny cooler
The bigger the better. For every 10 degree drop in temperature you add ten thousand miles to an automatic transmission so logic says the bigger the better. You should route it through the radiator first then to the cooler and then back to the trans.
Old Jun 6, 2009 | 11:17 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: tranny cooler
I would only do that in a northern climate or when I was planning on driving in cold winters.
Old Oct 1, 2009 | 11:26 AM
rick121's Avatar
Car: 91 Camaro RS
Engine: 3.1 liter
Axle/Gears: positrac off an 83 T/A
Re: tranny cooler
can you show a pic of your setup? just bought one from a guy here and I'm not much of a visionary type person... I have to see what I'm doing and your set up is exactly that.
Old Oct 1, 2009 | 05:03 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: tranny cooler
actually i am going to go just to the external cooler this weekend and see how it all works. hey ried got any pics??
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
apie2546
Sep 5, 2015 07:40 PM
