1987 IROC temp gauge not working
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: 1987 IROC temp gauge not working
The gauge should peg to max during crank (starting the engine). If it is not doing that, the gauge has 'kicked the bucket' or, no longer has power going to it.
Removing the wire from the sender (green single wire on drivers side head) and grounding it should max the gauge (key on). If the gauge maxes, the sender is bad.
That is really all there is to the gauge circuit.
The odds are the sending unit is bad/maybe unplugged.
Kool, thanks for the info....
Engine: TPI 305/ v6
What I did was, take the trim bezel and lens off the gauges and physically move the needle off the edge. I ended up putting a little bit more a a bend on the lip (of the gauge face) with some needle nose pliers to solve the issue. A few test 'starts', the gauge will ground before the starter turns, and reassemble. All was fine until the rest of the car fell apart around it.
That may or, may not help.
Engine: TPI 305/ v6
To remove the gauge though, the entire cluster does have to be removed as it is fastened from the back side. The dash itself does not have to be taken apart or removed though.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
My gauge is acting the same way. But for good reason, there is no wire or sensor in the head. So what i did was buy a new temp sensor switch, and I got 2 alligator clips. I attached on end of the clip to the body of the switch and the other to a good ground source. I then attached the other alligator clip to the male terminal of the temp switch and attached it to what I believe is the wire lead to the gauge. I turned on the IROC and the neeedle stayed MAXED out. I turned off the IROC and it still stayed maxed out. 5 minutes later I came out with a thermos filled with hot boiling water. I turned on the IROC and poured the hot water on the sensor. I checked the gauge and it was still pegged out. Im out of options here.
Ghettobird52
Jul 5, 2024 11:18 PM
mustangman65_79
Aug 11, 2015 03:17 PM
