Help with A/C cooling problems, PLEASE!
Old Jun 24, 2009 | 09:27 PM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
About a year ago I spent about $800 replacing everything on the a/c system. Compressor, evaporator, condensor, drier, blower motor, orfice tube, accumalator and added dual 12" Be Cool fans. The a/c blew in the upper 30's until about 2 weeks ago and now it wont blow below 68. I've checked the freon and it not low. Nothing blocking the condensor. Is there a way to tell if the compressor is going out or bad without spending $300 to replace? I live in South houston and it's pretty hot here right now. I'm not sure if something could be clogged. When I switched over, I pulled a vaccum for about 30 to 45 minutes and added the new oil to the compressor. Ever since I've had the car, the previous owner jumped something to where the clutch stays engaged with the a/c on. It doesn't cycle. Could this cause premature compressor failure?? The compressor does make a knocking noise with the a/c on. I'm not sure if I should try to switch to Auto Frost. What would I have to do or replace if I went that route. It just sucks spending $800 bucks a year ago, I don't want to spend that kind of money again! Sorry so long, just tring to mention everything. It was 100 degrees here today and is only getting hotter!!
Old Jun 24, 2009 | 11:15 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Help with A/C cooling problems, PLEASE!
Compressor staying on could be for several reasons.
1) Could be a variable displacement compressor instead of a cycling compressor. The variable displacement ones are supposed to be easier as they're not going on/off/on/off. They're simply a variable output type. The old GM R4 compressors are cycling. The GM V5 compressors are variable displacement.
2) Houston set an all time record high for June today (104°). Very unlikely that a cycling compressor would be cycling off in this heat even with a perfectly charged and functioning system.
Are you R-12 or R-134a?
Are both your radiator fans working properly? If they're not, the A/C performance will be dreadful.
Old Jun 25, 2009 | 10:59 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
HOTROD
Originally Posted by mikeirocz1
.........I've checked the freon and it not low.........
Did you use gages?
If pressures are OK your compressor is OK.
Even if someone disabled the cycling ability the compressor has 2 devices in it to protect itself.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Jun 26, 2009 | 05:27 PM
mikeirocz1's Avatar
The system was coverted to r134. I replaced the old compressor with a GM compressor. The GM compressor has a sticker that say r12 buts it's been converted. I'm not sure what model compressor it is. I called the dealer and the have a compressor kit for $446.60, R4 compressor for $382.43 or a A6 compressor for $611.17. Don't want to buy a compressor if mines not bad. I'm not sure if it's just so hot here it's not cooling as good. It started not cooling as good over the past 2-3 weeks as the temp went up. I put some leak dye in the system and couldn't find a leak. Should I convert back to R12 or autofrost?? I here those work better in high heat/humidity area's like here.
Old Jun 26, 2009 | 09:09 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
what are your pressures?
Old Jun 29, 2009 | 09:14 PM
mikeirocz1's Avatar
I checked the low pressure on the low side with a guage from the auto parts store and it was 65. I don't have a way to check the high side.
Old Jun 29, 2009 | 10:02 PM
Car: 1989 GTA
Hard to say exactly how loud the compressor should be.
Assuming your cooling fans are turning on when the A/C is on, the compressor wouldn't shut off if it's running 65 psi. The compressors tend to turn ON at about 45 psi and turn OFF at around 25 psi.
65 psi isn't cold enough to give you cold air. Needs to be down in the low 30's for that to happen.
Could very well be the compressor going out. If it's not compressing down to the low levels, it would be a sign. R-12 to R-134a changes often don't last more than a year in hot climates. It's pretty much impossible to get all the old R-12 chlorine out of the system no matter how much you flush it. And you use it more often than somebody up north would. They might be able to get 2-4 years out of a conversion.
Old Jun 30, 2009 | 12:50 AM
QuickStyle's Avatar
Car: 91 Z28
65psi low side could mean a few things, first thing to check is your fans are turning on. if they are then it could mean you are either over charged or you compressor is failing. i've seen r12-r134a conversions last for numerous years, and i've seen them only last for a month, its kind of hit or miss with the conversion. but if you are trying to troubleshoot an a/c system, you really need to be able to read both high and low side pressures.
Old Jun 30, 2009 | 09:05 PM
mikeirocz1's Avatar
When I coverted the system, I replaced all the components so there shouldn't be any R12. My friend has some guages I can hook up to the high and low side. What should the high and low side read with a/c on and clutch engaged and what should it read off? My fans are both running, I have the dual 12" puller becool fans.
Old Jun 30, 2009 | 10:04 PM
QuickStyle's Avatar
Car: 91 Z28
low and high side pressures should read the outside temperature while the a/c system is off
with the a/c system running the low side should be approximately 30-50 psi depending on the outside temperature, hotter the outside temp, higher the pressure. high side should read 225 or higher also depending on the outside temp, hotter the outside temp, higher the pressure.
these pressures are approximates only, humidity plays a factor also.
Old Jul 1, 2009 | 01:20 AM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
one thing i have see happen before, is the orifice tube break apart.. just a thought :P
Old Jul 25, 2013 | 12:47 PM
radiateu2's Avatar
clogging or debris in orifice tube
chazman
Aug 28, 2018 03:25 PM
greenyone
Aug 29, 2015 11:08 AM
chazman
Aug 22, 2015 02:01 PM
BikeFarm
Aug 11, 2015 11:35 PM
