another a/c delete set of ???
Old Jul 4, 2009 | 10:42 PM
Canadianguy2006's Avatar
Car: 1990 Trans Am GTA
Engine: 350(5.7L)
Axle/Gears: 3.23 posi
ok i have pulled all my a/c stuff out, and currently i have the two holes exposed on the firewall. Before i put the delete box on i have some questions.
I have read on here that i should get a non-ac blower motor, and that the wiring for the motor is different on a/c motors, do i really need to get a non a/c motor? would a new non a/c impeller work on the old motor? and i do i need to reconnect the motor cooling tube onto the box?
oh and if i did need to get a new non a/c motor do they still make the pigtail connections for it so that i would just splice it in place of the old a/c plug?
thx
Old Jul 4, 2009 | 11:07 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: another a/c delete set of ???
When I did mine, The old blower motor didn't fit the Ac delete box, it was too big. The Ac Delete box uses a smaller blower motor. Also when I did mine, The blower motors used the same connector.
Old Jul 5, 2009 | 12:54 AM
Engine: 350(5.7L)
is there any differences between an 88 and a 90 in those parts/wiring?
and where did you get your box from, mines from hawks
Old Jul 5, 2009 | 01:14 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
When I put the A/C delete box in my '85, I re-used all the wiring that originally went to the A/C box.
You do need to get a non-A/C motor, and you do need to reconnect the cooling tube, but the one from your A/C box won't work.
Old Jul 5, 2009 | 01:18 AM
Engine: 350(5.7L)
hehe ok next question would be where should i get an updated cooling hose and where do i hook it into?
Old Jul 5, 2009 | 01:26 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
It hooks up just like it did on the A/C box.
I don't think anyone makes reproductions, so you'll need to buy an original or look in a junkyard. Chances are, if you find one in a junkyard, it'll have the entire A/C delete box and all required components attached to it.
Old Jul 5, 2009 | 01:30 AM
Engine: 350(5.7L)
dang, i'll have to try the dealerships the junkyards around here have had all their 3rd gens stripped of hvac stuff including boxes, but i might get lucky i'll check again
Old Jul 5, 2009 | 01:26 PM
Engine: 350(5.7L)
ok i have been looking for a new non a/c motor online and have come up with some options, but does anyone know the Delco part # that has the two prong wiring connector but is non a/c? i think it might be 1580666 but can't get a look at the motor body in any pics
Frozer!!!
Jan 19, 2024 04:55 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
