Fluid level sensor
Car: 87' IROCZ-Z28
Engine: 350 T.P.I Bolt-ons
Axle/Gears: 3.73 posi
Fluid level sensor
I believe i have located the fluid level sensor on my radiator but nothing is attached to it. My question is as long as i watch my antifreeze level is this sensor hook-up necessary?
Car: 87' IROCZ-Z28
Re: Fluid level sensor
Hmmm... well then would you know what it might be? It is on the passenger side. I looks like a small maybe half inch metal prong that sticks out. It looks like it should plug into something but there are no hanging wires that i could find to hook up to it.
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
have a pic by chance? Is the radiator out of a different vehicle maybe?
Car: 87' IROCZ-Z28
I believe that the radiator is original I am the 3rd owner and the one before me kept an extensive set of receipts and i looked through them and did not see anything about it i will try and get a pic up soon
Alrighty, we'll be lookin forward to the pic, then we can really help you out!
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
GM replacement radiators have that stupid hook up even though they aren't used for the most part.
What model had such futuristic technology you ask ? The digital dash cars that had the DIC (driver information center)
Want a picture of the switch?
https://www.thirdgen.org/forums/cool...ss-my-fan.html
The radiator in my Firebird came straight from the deanship. It wasn't' an option to get a radiator without the switch though, you could omit the cooler if you had a 5-speed (like mine)
Now you know.... and knowing is half the battle.
To add a little humor.. this was an option for these cars (if you got the digital dash). The DIC also showed doors ajar, hatch and low washer fluid (probably something else useless too that I missed). I'm sure it seemed special at the time.
The exact same thing my base model 86 Daytona and a friends 87 Topaz had stock (many moons back)
Car: 87' IROCZ-Z28
Well there you go. So I guess i will just have to deal with a useless switch that makes that does nothing for my car. Thanks for the info.
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Yep, unless you have a Digital Dash with the already mentioned Driver Information Center (Trans Am's Only Plz) then that little switch is just there for looks
Engine: TPI 305/ v6
To add an answer to the original question...
As long as there is coolant (cold) in your recovery tank (or overflow if you like), genrally,the radiator level is fine.
Cool! Problem solved. I've got several from the dealer and I have never seen this before though. Strange.
Springster
Sep 13, 2015 01:38 PM
