what the hot??
Old Jul 31, 2009 | 07:54 PM
F-Body_Fetish's Avatar
Car: 1984 Camaro Z/28
Engine: 350 SBC
what the hot??
I've just started to drive my car to work regularly. its about a 25 min drive on every type of road. I'm having some issues with the voltage dropping down after about 10-15 mins of driving and throwing my guages off. temp, press, gas. with less volts my temp goes up and my gas guage goes up and my oil press goes down. anyways, my heat goes way up and i put the heater on full blast to make keep it in check. it only goes up when my volts go down, but I figured I turn the heater off the temp will be high but if it doesnt rise its just the guages. thing is, it does rise. and its weird. the temp is low in traffic but high on the highway, the opposite of almost every other car. its a 350sbc with a couple smal mods done, cam, intake, carb, exhaust. i'm using a stock rad and an electric fan from an '87. the coolant is full, anyone have any explanation? seems to get hotter as it stays in higher rpms.
Old Jul 31, 2009 | 08:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: what the hot??
Do you have the air dam under the car? Usually, overheating on the highway but not at idle indicates that the air dam under the car is missing.
Old Jul 31, 2009 | 10:55 PM
Engine: 350 SBC
Re: what the hot??
Yup, I've got the dam on. its not necessarily on the highway, but whenever i'm at rpms above 1600 for a length of time. and the water pump is brand new. so are the belts. and tstat.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
