Help with single fan. can't get it to work
Old Aug 4, 2009 | 05:05 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
I have the main black, and black/red wires hooked up. Nothing. But there is a little connector on the passenger side of the radiator. I am not sure what wire goes there and if it needs to be on for my fan to work. Guessing its to tell the fan when to come on based on coolant temp.
How would I test to see if my fan is broken?
thanks
Old Aug 5, 2009 | 11:11 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: Help with single fan. can't get it to work
You only have one fan on that car? You could start by unplugging the fan connector at the fan itself. Find the proper terminals and apply power and ground to it straight from the battery. (Careful where you put your hands here)
Old Aug 7, 2009 | 08:58 AM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Yeah I have the single stock fan.T hanks for the tip. My motor was shot so I went ahead and replaced it. The fan works good now. thanks!
Old Aug 7, 2009 | 08:41 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Glad you got it.
Jake_92RS
Jan 28, 2020 10:37 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
sailtexas186548
Aug 26, 2015 03:32 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Jake_92RS
Aug 11, 2015 10:39 AM
