orifice tube location on 1988 camaro
I'm working on my nephews camaro and was gunna fix the air but not sure where the orifice tube is at. Anybody know for sure? I did remove a line back by the firewall and it looks to have some plastic thing in the line but it won't full out. Would this be it?
Car: 88 Camaro
Engine: L98 350
Re: orifice tube location on 1988 camaro
The smaller line where it goes into the AC box on the firewall. Have to pull it out with pliers usually and pay close attention to how it's oriented. I've always thought it looks backwards when it's in right.
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Grab it with some needlenose pliers and turn it and pull and it should come out . Thats what I have always done even working at a shop .
Car: 86 Z28
Axle/Gears: 3.42 posi
I have this same problem. I pulled on it so hard i thought it would break and it still doesn't come out. btw, it did start to fall apart and now the front half of it is broken off and it is still stuck in there. how the **** do i get this out????? I'm afraid of pull on whats left of it and having that break and then i will never get it out.
also the replacement one i have only has one o-ring and it was from an ac shop that knows what there doing.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
http://www.acsource.com/index.asp?Pa...ROD&ProdID=374
Haven't used it. But it looks like it would do the trick.
Car: 86 Z28
Update: I had to bring mine to a ac shop and they got it out with a special tool for $40. They should just slide right out, they said it wasn't coming out because the fitting got twisted when I took it off( it was very corroded and I was careful to not bend it but it moved a little bit and that did it. So I talked to another ac guy and he said to use drill bits by hand and have a vacuum on it to remove the burs, and it worked really good. I found out now though that my compressor leaks around the shell so its not gonna work for to long.
A new compressor is like $250 but with that i could get some sfc's. So I guess I will be driving with the t-tops off.
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
https://www.ackits.com/pc/000118CP/C...essor+-+Clutch
