new parts but now I run hot
Old Aug 6, 2009 | 04:57 PM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
Axle/Gears: stock axle
I posted before about this but I left out something that I just relized.
I have a carb 350 sbc in a 88 z28. I did a top end rebuild. New intake, carb, dst, water pump, psp, alt. My car used to run at 190 degrees with the old stuff. Now it runs between 230-250. I just relieved that I did not use the restrictor plates that came with my edelbrock intake gaskets ( the rectangle metal things). I also did not hook up my heatercore. could this be the problem? I do not want to redo the intake gaskets if I not have to.
thanks in advance
Jesse
Old Aug 6, 2009 | 05:00 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: new parts but now I run hot
when is your fan turning on at?? (single or dual fans??) is it getting hot with the fans on, or are the fans not turning on until 230?? Are you going by factory gauge or a laser temp pointer??
Old Aug 6, 2009 | 05:14 PM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
i am turning one on manually at 190 degrees. I never used the second fan before. no computer controls. I am going by factory gauge just like before the rebuild.
Old Aug 6, 2009 | 05:22 PM
renemedrano842's Avatar
Car: 92 GTA
Transmission: 5 Speed
Axle/Gears: 3.27 posi
what temp thermostat did you use? and did you set the timing at the same base timing
Old Aug 6, 2009 | 05:23 PM
Engine: L98 494hp
Is everything seemed sealed up good??? no leaks?? Did you put in a new thermostadt?? Does it feel really hot, or is gauge saying that?? How long have you driven it after these changes, right away (could be air bubble)
Old Aug 6, 2009 | 05:25 PM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
i used a 180 thermostat and timing is set at 12 degrees now. I tried 10 degrees also with the same result.
Old Aug 6, 2009 | 05:31 PM
Engine: L98 494hp
sometimes the restriction plates help cool it off, get a laser pointer and take temp of upper and lower hoses if you can to see difference, (or use hand to feel difference). you might have a sticking thermo. if one is way cooler than other it's sticking
Old Aug 6, 2009 | 08:09 PM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
I just looked at my paperwork and i have a highflow wp from edelbrock. Do I need a highflow thermostat? I have a cheap autopart store(new) installed now.
Old Aug 7, 2009 | 10:14 AM
Engine: L98 494hp
It shouldn't matter, but maybe give it a try.....start with the easy ideas, and then keep going until you find it.
Also, what did you do with the heater core lines you didn't hook up....did you just block them off??? if so that's you problem right there. You should have to lines from heater core to engine......you have to connect the ones that come off engine together.
Old Aug 7, 2009 | 11:07 PM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
i hooked up the heater core today. The car ran 20 to 30 degrees cooler! I guess it was the heater core but it still does not run at 190 like it used to. thanks again.
Old Aug 9, 2009 | 04:00 AM
oil pan 4's Avatar
Car: 89 Firebird
Good you figured it out.
I was just about to say you must have a thermostat by pass. If you do not have one it causes all kinds of problems when you get out on the high way. In the city its normally not noticeable.
People removing the by-pass has cracked countless heads over the years.
theshackle
Mar 5, 2017 06:37 PM
jackhammer
Aug 15, 2015 10:04 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
