heater/defrost installation
Old Aug 6, 2009 | 06:30 PM
marine68's Avatar
Car: 89 IROC Z28
Engine: 5.7 L Edelbrock perf /holley 3310
Axle/Gears: BW 9 BOLT 3:27
the a/c heater components are currently removed from my camaro, to include all the a/c components and the engine runs with a a/c delete pulley. that's fine but i want heater,defrost, vent system to work. the wiring harness for the blower motor is there, plus a a/c heater control panel installed in the dash area. i don't know if the panel is good. i see that thirdgen ranch has the blower motor/ac fiberglass housing for sale to include the motor. my question is, can i install this in the firewall area and connect the wires to the blower, and then will the air circulate to the vents in the window for defrost and will the heater work. i think air will leak out when the freon tubes were installed.
Old Aug 19, 2009 | 12:12 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
AIR APPARENT
Air from the blower does not enter the freon tubes.
Because you’re getting the same type of assembly that was removed there should be no compatibility problems.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
