Heater Problem
Old Sep 10, 2009 | 02:26 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Heater Problem
I converted my car over to A/C delete and I have the box and blower motor and everything installed on my car. The problem that I am having is that the heater isn't blowing as strong as it should be. Also, what I noticed is that the blower motor only runs when the heater swtich is in the low or high position, not either setting in between. Could I possibly have messed the wiring up somehow when changing it over? Do I need the a/c delete heater controls? Could anybody who has done the a/c delete swap give me a hand here?
Old May 27, 2013 | 10:21 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
Re: Heater Problem
I'm having the exact same problem, did you figure out a solution to this?
Old Jun 13, 2013 | 01:55 PM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: Heater Problem
Check the blower resister pack.
Old Jun 16, 2013 | 04:12 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Heater Problem
My wife's Alero had a similar problem, it would blow on "4" or on "1" but not in between. Turned out to be the blower motor had to be replaced. I'd do what McQuigg suggests and check the blower resisters.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
