ac vents not letting air out
Old Sep 17, 2009 | 09:42 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I put a new vent blower motor in last week. Now I can hear the motor blowing as I turn the ac control **** up or down.But very little air comes out of vents or defroster,I got the car back in May blower motor never worked since I got it.What can I check to fix this prob?
Old Sep 17, 2009 | 11:57 PM
Richwiz1's Avatar
Re: ac vents not letting air out
Can you hear like a vacuam leak when you move your controls? IF you can take your controls out there is a valve with a bunch of vacuam lines hooked to it it needs replaced it controls your vent doors. Hope this helps
Old Sep 18, 2009 | 03:59 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
also make sure the 2 hardlines in the engine bay are hooked up; i made that mistake and could never figure out why my vents wouldn't move anymore....
Old Sep 18, 2009 | 09:13 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks guys I will look into those parts in the morning.
Old Sep 19, 2009 | 09:03 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
I checked the hard lines and vacume lines all are in tack. But I still dont have much air coming out of the vents.
Old Sep 20, 2009 | 07:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sorry, I can't recall. Does the cage install so that the blades turn in a specific direction? If so, it may be pulling instead of pushing air.
JamesC
Old Sep 20, 2009 | 03:21 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Mine will only turn one way.Its blowing but not much its like my 92 silverado blows as much on low, as this camaro blows on high. I wonder if there is a vent door semi closed somewhere I can see the vent door open under the blower motor when I turn ac on.
Old Sep 20, 2009 | 03:59 PM
Richwiz1's Avatar
Did you check the valve in back of the a/c heater controls it is round an controls the opening and closing of you vent doors Ive had to replace mine twice
Old Sep 20, 2009 | 04:09 PM
JamesC's Avatar
If there's a vac leak in the system, the default setting is defrost. Doesn't sound like the case here. I'd remove the blower motor, give it a once over, and test it. You may have a bad motor or a loose cage. Moreover, don't expect the motor to blow as hard as a new car. Won't happen regardless of what you do.
BTW, did you have to transfer the cage to the new motor?
JamesC
Old Sep 21, 2009 | 07:21 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
The motor came out of a 90 s10 blazer, I think almost all are a swap. The motor runs fine I meant to say I can watch it turn from underneath the dash when I turn ac on and the flapper door opens to suck more air.Maybe its doing all it can but that is very little air pressure.Thanks for all the helpful info.
Old Sep 22, 2009 | 01:35 AM
Richwiz1's Avatar
IS it switching from low speed to med to high?
Old Sep 23, 2009 | 05:23 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Yes it is switching speeds but not blowing a strong volume of air out of the vents or defroster.Is there a vent door somewhere that could be semi closed? And James I didnt change the cage from other blower , I could not see how to take it off without breaking it.
Old Sep 23, 2009 | 05:34 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
For what little air is moving, does it blow from different areas if switched from the control ?
There could just be massive amount of dirt/debris collected on the evaporator coil screen that is blocking the air from getting to the ducts.
As long as the cage wheel was the same size and the blades pitched about the same, that shouldn't matter.
Old Sep 23, 2009 | 06:53 PM
JamesC's Avatar
Exactly. Is the S10 the same?
JamesC
Old Sep 23, 2009 | 09:47 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
The controls move the air to defrost,heat and vent. Yes the s10 fan was same. Ok this evaporator coil that could be the culprit where is it located and how do I get to it?
Old Sep 24, 2009 | 03:20 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
is there air flow the same (weak) in the heat mode, too? if not, then how would the airflow differ from heat vs. a/c or defrost? doesn't it all come across the evap coil? i've heard a possible cause of this could be a leak in the ductwork behind the dash... if it does split somewhere for heat vs. a/c, then i'd be looking at the evap with debris as mentioned, or vacuum issues. just my .02...
Old Sep 24, 2009 | 05:09 PM
deadbird's Avatar
Engine: TPI 305/ v6
See attached image. The top of the blower box can be removed. It's a few 9/32 hex screws and maybe a 10mm bolt holding it to the firewall.
Old Sep 24, 2009 | 09:58 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
To be honest I have not tried the heat yet.I will take the cover off the evaporator Sat and let you all know what I find. Thanks again for all the help.
Old Sep 27, 2009 | 09:03 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
The evaporator coil looked dirty what is the best way to clean it?
Old Sep 21, 2011 | 04:02 PM
curtalert89's Avatar
Car: 91 Camaro R/S
Engine: Tbi 350
Transmission: auto4
Axle/Gears: Stock
alright so im having the same problem with my 88 rs v6, the vacuum lines are good, its just not blowing out of the vents really at all, it has a new heater core, so ac and heat work, but i dont feel anything coming out, were would the hard lines be located under the hood, i think that it may be the problem, the lady i bought the car from was replacing the heater core, and she said that she had not fully connected it all back together, pics would also help
Old Nov 22, 2011 | 09:02 PM
Lively13's Avatar
Car: 1982 Camaro Z28
What is the actual name of the part?
Ive been looking on autozone.com because air only blows out the top "defrost" vents, and wont change to any other vent. And someone stated that if it only blows from there that needs replaced..
PLEASE HELP.
Old Nov 23, 2011 | 02:01 PM
Lively13's Avatar
ANYONE?
Old Nov 23, 2011 | 02:20 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
If your only getting air out of the defrost vents, you've got a vacuum problem.
Old Nov 23, 2011 | 04:30 PM
Lively13's Avatar
I got that part, but before i try replacing all the lines cause i figure that may be complicated??? i donno. I figure id replace the part that all the lines plug into, But what is that part called?
Old Nov 23, 2011 | 05:40 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
theres 2 vacuum hard lines in the engine bay near the ac box. one is the inlet for the ac controls, the other is an outlet that goes to the heater diverter valve. if the inlet doesnt get vacuum the controls stay on the default setting which is defrost.
if that line is hooked up correctly, then you have a vacuum leak somewhere between the engine bay and the back of the ac controls.
Old Nov 23, 2011 | 07:19 PM
Lively13's Avatar
Would you happen to have a picture of the inlet and outlet?
Theres just so many cables under my hood from when i got the car, My mechanic said he thinks its because they went from tuned port to Carbs.
Point being that its hard to tell whats what, and im still learning when it comes to all this.
Old Nov 23, 2011 | 07:51 PM
travis401's Avatar
Car: 91 Camaro RS
not one at work. should be the only 2 plastic vacuum lines coming out of the firewall with the ac wiring harness.
Old Nov 23, 2011 | 09:02 PM
Lively13's Avatar
My flashlight may not be doing the job, imma have to wait until tomorrow.
If between now and tomorrow you are able to get a picture that would be very helpful.
BTW Thanks For Your knowledge thus far.
Old Nov 23, 2011 | 11:30 PM
travis401's Avatar
Car: 91 Camaro RS
the one with the elbow is the inlet. the straight one is for the diverter valve.
Old Nov 23, 2011 | 11:58 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I had to replace my fan motor when this happened to me. The fan motor I had in the car still worked but not real strong. So i got a new one and it blew like crazy! Windows up and hair blowing! Very strong.Maybe something in the fan motor went out making it insufficient air,
Old Nov 24, 2011 | 12:18 AM
travis401's Avatar
Car: 91 Camaro RS
if it blows only out of the defroster its not a fan problem, its a vacuum problem.
Old Nov 24, 2011 | 01:05 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Would his 82 even have a diverter valve? I'm guessing it's carbed, and I thought those didnt have one, just the other line. True for my 85 at least.
Old Jun 3, 2012 | 10:11 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
my 86 doesnt have a valve. coolent flows to the heater core all the time, and iv only got 1 hard line.
Old Jun 5, 2012 | 02:26 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Product called "KOOL-IT" made for this purpose
RT
Old Sep 22, 2012 | 12:51 PM
conleyh2006's Avatar
Car: 1992 camaro rs
Engine: 305 v8 tbi
i have a 1992 rs 305 v8 camaro i found the vacume leak behind the controls the vacume piece on the right side the clip that holds it together broke off does anyone know what this piece is called and where i can purchase one we dont have any old camaros in the junk yards around here they have all been crushed lmk thanks
Old Oct 2, 2012 | 07:45 PM
Car: 1992 camaro rs
Engine: 305 v8 tbi
i found the piece needed to fix the vacume leak but it still will not change air flow from the defroster to the vents. Does anyone have anymore ideas on what could cause this? Any help is appreciated
Old Sep 19, 2015 | 01:05 PM
Biggd4355's Avatar
Dust and dirt can collect in the condenser and restrict the airflow. So you have to access it and clean it. I would like to know the best way to access it so I can clean mine.
Old Sep 19, 2015 | 01:06 PM
Biggd4355's Avatar
or dirt in the evap coil.
Old Jul 19, 2016 | 03:20 PM
Biggd4355's Avatar
is anybody going to talk about the condenser plugging up with lint and dirt? Newer cars have air filters, these older vehicle just suck air thru this small radiator. The more blocked it gets, the less air movement. Hot air as well as air travels thru the same area.
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
