Cooling fan problem
Old Oct 7, 2009 | 01:27 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Cooling fan problem
Fixed
Old Oct 7, 2009 | 08:49 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Cooling fan problem
About the only other thing I would know to check is the connections for poor contact & maybe corrosion??
Sorry it's probably no help to you.
Old Oct 7, 2009 | 10:15 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I would start with seeing if the fan switch is still grounding the second time.
At the time the fan should kick on again, pull the wire and ground it. If the fan runs, the circuit is fine. Test for resistance to ground through the switch (at same temp, no fan on), if a multimeter shows noting (open circuit), the switch is bad.
Old Oct 7, 2009 | 10:52 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Sounds to me to be the relay!
Old Oct 10, 2009 | 11:59 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I never had any luck with the fan switches, from cheap to hypertech they all were crap.
I installed a seperate fan controller from Flex-a-lite and never looked back - it's been great for 3 years now, fully adjustable, manual toggle control options, always works like it should.
Old Oct 13, 2009 | 02:33 PM
red_wing45's Avatar
Car: 91 comaro
Engine: v6
hi i would like to know how i re hook up a after market toggle switch to my fan,were do i hook it out pass the fire wall. ty john
Old Oct 13, 2009 | 06:58 PM
Car: 87 T-Top GTA
I think your better off starting a NEW thread, "On How To......." Or just do a SEARCH!!!!!!!
Jordan Dorn
Jan 29, 2017 05:55 PM
Zrated83
Jan 10, 2011 06:12 PM
seannana
Jun 15, 2010 08:44 PM
Zrated83
Jul 23, 2006 09:59 AM
kakarot
Apr 4, 2004 03:13 PM
