Fan not turning on
Old Jul 19, 2006 | 09:01 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Fan not turning on
Hey guys, my bro has a 92 RS with the l03 tbi. Well our problem is the fan will no longer turn on. It has one single fan. Checked all the conections and they seem fine. Checked the fuse and that was good also. I read during a search that your fan is supposed to come on if you turn the ac on, is that true? When I took it for a drive I turned the ac on but no fan. Im thinking it could be the fan switch or maybe the relay?
Old Jul 19, 2006 | 09:06 PM
fastride90's Avatar
hay try to pull the coolin temp sen or fan swith or tap the fan
Old Jul 19, 2006 | 10:49 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Dud fan switch or faulty fan relay. Ground the wire to the fan switch and if the fan comes on, then its a faulty fan switch.
Old Jul 20, 2006 | 04:04 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Well, we grounded the cooling fan temp. switch, and heard a clicking sound coming from the relay switch on the firewall. We unplugged the relay and it looked like terminal A was a little burnt or golden. Could we have burnt it while we were grounding the fan switch?
Old Jul 21, 2006 | 02:26 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Fan will turn on w/ ac on (tbi cars only)
POZ
Old Jul 21, 2006 | 12:24 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
No - the switch grounds that circuit normally anyway. I'd change the relay and go from there.....
Old Jul 22, 2006 | 06:11 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I went through this on my RS awhile back, sometimes the fan would work and sometimes not, ended up being the fan motor bearings were going out and it would lock up sometimes, I got a new motor for about $30 at O'Reilly's. So make sure the fan turns smoothly before you start tracking other stuff down.
Old Jul 23, 2006 | 09:59 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
It was the fan motor. Tested the fan switch and relays and they were all good. So I decided to power the motor straight from the battery and nothing happened. Got the replacement and all is good.
RazorN8
Jan 7, 2022 11:44 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bryanwood74
Sep 24, 2015 09:50 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
